tire size/body work
Old Sep 14, 2004 | 12:20 AM
dhag911's Avatar
dhag911
tire size/body work
ok I am going to ask 2 questions in the same post
I just got my lift and front end rebulit this weekend now i need new tires before i get the front end aligned. The choices are 32 or 33" BFG A/T or Yokohama geolander A/T which size is going to be the best for traction and looks on my 92 F-150 it is a 4" lift. I will post some pictures when i get the tires on and all the body work done.
here is the body work question the rust that I have they are going to fix with fiberglass. How does that compare to a patch panel? This is how the tech told it to me: Fiberglass is cheaper and when you do a patch panel it burns the protective coating off where you weld and will rust there in a few years where as the fiberglass will last 5 years and then start to rust. it is about 1/4 of the price of a patch job.
Old Sep 14, 2004 | 08:20 AM
Morky's Avatar
Morky
patch panels,
something new out, well at least to me
is they now have an epoxy/glue that is used by many body shops
so no welding is required.
Does it last ???
not sure many have lots of yes and no's on this type glue.
I welded mine in, with a spot welder,
only a few spots, and no warpage, and fiberglassed over to make final smoothness.
Only been a few months, so can only wait and see..........
Old Sep 14, 2004 | 10:26 AM
ssn randy's Avatar
ssn randy
get 33" to fill the hole. look in my gallery, the tires are 33" with 3" body lift. much smaller and the wells look huge and tire little.
