Aerostar Ford Aerostar
Power Steering Problem
Old Jun 16, 2001 | 04:55 PM
Blackgsd's Avatar
Blackgsd
Anyone have an idea where water could get into the powersteering?
I have replaced the PS pump 3 times in 2 years.
I have had it to 2 mechanics and neither can figure out how the water is getting in there.
One summized possibly it is coming through the vent hole when it rains if the rain drips on it.
I keep thinking that 193,000 miles a pump every so often isnt to bad but this is getting annoying.
Thanks
Ed
Old Jun 19, 2001 | 04:23 PM
1986broncho2gal's Avatar
1986broncho2gal
When we had our 87 Aerostar, the power steering just up and quit. I drove the hunk of junk without power steering until a drunk driver hit it and put it out of its misery.
Old Jul 9, 2001 | 04:07 PM
aerocolorado's Avatar
aerocolorado
That is a weird one. There is no physical connection between power steering and cooling systems. If it truly is water getting in then PS fluid should also be able to get out. Assuming no leaks from the rack, then any water would have to enter from the reservoir side. If you've replaced that many pumps due to the same problem, you've either got someone topping up with the wrong fluid or a vindictive ex.
Old Jul 10, 2001 | 08:37 PM
biederboat's Avatar
biederboat
