what have i got
Old Sep 13, 2004 | 09:47 PM
albracht2000's Avatar
albracht2000
what have i got
i just purchased a 78 ford 4x4 short bed, f100 f150 not sure. owner tells me it has a 390, auto tranny. what front end do i have, rear end, transfer case etc. was this a factory big block truck. what probably came in it. any help with this i would appreciate. i'm about to start restoring. what is the bolt pattern on this trucks lug pattern. small bearing rear end or big sont know if there is a differnce, but just heard there was. how do i tell if it is a 390.
thanx for the help
Old Sep 13, 2004 | 09:51 PM
highboy1975's Avatar
highboy1975
well, if it has a 390 in it, it's not factory...the 390 was only in 2wd trucks. as far as your running gear, it's most likely a 9in. in the back, a dana 44 out front, and a np205 tcase if its part time 4x4. your truck probably had a i6, 351, or a 400 to begin with being that its a 78. these are all just guesses though. just go to the vin decoder at the top of the forum and pug your vin number in. this will tell you alot.
Old Sep 14, 2004 | 09:01 AM
73Custom's Avatar
73Custom
highboy1975 is right, the 390 was not used in '78. '76 was the last year the factory used it - but it could've been swapped in rather easily. There are a few easy ways to tell what engine you have. Count the number of bolts holding on each valve cover. And do the spark plugs angle like this //\\ or like this \\\\ ?
Marty
