Truck stalling -- help!
Old Sep 13, 2004 | 04:59 PM
firewolf's Avatar
firewolf
Question Truck stalling -- help!
I have a "91 F250 with a 7.3L. If I let off the throttle quickly it dies. If I can let go of it slow enough it doesn't. It always starts back up immediately. Any ideas?
Old Sep 14, 2004 | 05:38 AM
trike1946's Avatar
trike1946
I am new to diesels so I am not sure if I can give you the right answer, but three threads up is having a similar problem, and got some advice. Good luck with it.
Old Sep 14, 2004 | 06:12 AM
bilder12's Avatar
bilder12
firewolf ... try changing the fuel filter first and make sure all the seals are in place. If that dont work try looking over the electrical system and make sure there isnt a wire chaffing around the injection pump or the connections on the pump are tight. Get back with your findings.
Old Sep 14, 2004 | 02:57 PM
firewolf's Avatar
firewolf
Everything seems to check out in that regard. It could be the pump but I'm hoping for something simpler, right?
Old Sep 17, 2004 | 06:19 AM
BigGunZ's Avatar
BigGunZ
Mine does the same thing every other year or so. It is easily fixed by turning up the idle screw. It is adjustable on these older diesels. They usually will back off slightly over time due to vibration. There are other possible causes but more than likely it's just the idle.
WALFORD'S 56
Ohio Chapter
93
Feb 1, 2010 02:56 PM
Tangi Cowboy
Louisiana Chapter
146
Jul 2, 2009 08:07 AM
Tangi Cowboy
Louisiana Chapter
232
Mar 2, 2009 11:19 AM
effie_man
Nov 26, 2007 11:12 PM
ClodsFe
Oklahoma Chapter
Feb 6, 2004 10:52 AM
