1978 - 1996 Big Bronco
Diagnostics port
Old Sep 13, 2004 | 04:32 PM
pilot815's Avatar
pilot815
Diagnostics port
On my 1988 bronco i just spliced in a new diagnostics plug. Upon hooking up the computer it was dead. It was suggested that maybe it was not being grounded. Which wire is the ground and how can i fix it?
Old Sep 13, 2004 | 06:00 PM
genueix's Avatar
genueix
Was it dead before AND after you modified it?
Old Sep 13, 2004 | 06:32 PM
pilot815's Avatar
pilot815
Beofre i chnange it, it was cimking off.
Old Sep 13, 2004 | 08:10 PM
Trublufords's Avatar
Trublufords
My NGS on 88 doe'nt power up off data link (under hood plug)96 OBDII is powered at data link- same fuse as cigar lighter.You did mean scanner is dead???
Old Sep 13, 2004 | 09:08 PM
pilot815's Avatar
pilot815
Sorry about that reply, i had just woke up and had no idea what i was typing, lol. I am using a Snap-On MT2500 scanner. It has a direct hook up that goes to the batt. on the truck. The ground, however, is through the plug so i'm told. It won't fire up the way its supposed to. On the plug while wiring it one of the ports had two wires while my original only had one coming out of it. So i spliced them into the one wire, could this cause problems.
