Aerostar Ford Aerostar
Aerostar Trans Pan ?
Old Jul 19, 2001 | 09:57 PM
Ed's Avatar
Ed
Hello fellow Aerostar owners/enthuiasts! Just wondering, do you know of any aftermarket manufactuer that makes a replacement transmission pan for the factory 4-speed auto transmission used in the Aerostar? I am mainly interested in a stock-type pan with a drain plug that would make ATF fluid changes much easier. Looked in the current Ford Motorsport catalog, and only saw pans for c-6's, 5.0L Mustangs, etc. Any info, or thoughts on this matter would be appreciated. Thank You.
Old Jul 20, 2001 | 08:01 AM
MarkP's Avatar
MarkP
I havn't found an aftermarket A/T pan with a drain plug, but you can add a drain with plug to the factory pan. Both Parts America and a couple of other auto parts chains carry these after market plugs for trans pans in the "Help" parts section for small replacement parts and tools. Ask the counter help if you can't find these plugs. You basically drill a hole in the pan and use the kit with gaskets that come with it. Works slick and I think sells for less then $10 if memory serves. Makes A/T fluid draining much easier when changing the trans filter.
-Mark
Old Jul 21, 2001 | 07:11 PM
nitro94's Avatar
nitro94
RojoStar
Aerostar
Apr 3, 2012 07:32 PM
Travismcd
Aerostar
Feb 16, 2011 06:39 PM
psf
Aerostar
Dec 26, 2004 03:32 PM
ecleslie
Aerostar
Aug 31, 2004 06:37 AM
dwilcoxx
Aerostar
Jun 9, 2000 12:15 PM
