Sponsored by: Real Truck
measuring for lift
Old Sep 13, 2004 | 04:21 PM
jake00's Avatar
jake00
measuring for lift
I wasnt sure what I should mesaure, to determine if my truck was level or whatnot, so i measured from the ground to the fender over each wheel. i measured 38in in the front and 40.5 in the back. This is kinda odd tho cause it looks level, several of my freinds thought so too.
Anyway, I'll probably go with a 2.5 kit up front, and a 1 or 2 inch kit in the rear. maybe the f350 blocks???
Did i measure correctly?
Old Sep 13, 2004 | 04:40 PM
southernfordman's Avatar
southernfordman
thats the way i would measure from the ground to the top of fender and that sounds right 2.5 up front to level it. on my ranger it sits un even and i am going to put a 6inch lift up front and 4 inch in the back
Old Sep 13, 2004 | 05:26 PM
DS02F250's Avatar
DS02F250
You measured correctly. And a 2" or a 2.5" leveling kit up front will level it out w/o a need for blocks in the rear. I'm going to go with DayStar 2" coil spacers ($100) up front to level it and ProComp ES3000 shocks ($37 ea.) all the way around to retain the stock comfort ride.
My $.02,
DS
