Bronco II Ford Bronco II
power booster
Old Sep 13, 2004 | 10:59 AM
dogg16's Avatar
dogg16
power booster
I thought I needed a power booster because the pedal is low and the engine is surging but I saw a test in the chilton manual and according to that the power booster is o.k.when I performed the test...guy at the parts store said it might be the pressure differential valve but I can't find one on my 86 b2 2.9...I am stuck..could the booster pass the test and still be faulty?? anyone know where the pressure differential valve is??
Old Sep 13, 2004 | 11:51 AM
Help I M Stuck's Avatar
Help I M Stuck
follow the brake lines down from the master cylinder..they will go into a block..located close to/near the frame.
