56 light switch removal
Old Sep 13, 2004 | 08:12 AM
chan's Avatar
chan
I have most of the wiring removed from my 56 but can't seem to get the headlight switch out of the dash. I have tried rotating it but can't get the bezel to disengage. I am a newbie - is there a trick to this?
Old Sep 13, 2004 | 01:21 PM
Jag Red 54's Avatar
Jag Red 54
I have the 56 switch in my 54. There is a spring-loaded button on the base towards the back. If you push and hold that in, then the **** and shaft will slide out. Then you can unscrew the keeper bezel on the front. Good luck, John
Old Sep 13, 2004 | 01:36 PM
chan's Avatar
chan
Thanks John,
I never would have found that!!!!
Jason
Old Sep 13, 2004 | 03:29 PM
Jag Red 54's Avatar
Jag Red 54
Just wait till you try and remover the vent handle! Good luck and have fun with your project. I really miss the days when I was redoing mine. John
Old Sep 13, 2004 | 03:51 PM
merc546's Avatar
merc546
John:
Come on up to Michigan I think I can find something for you to do.
Chuck
Old Sep 13, 2004 | 05:07 PM
Jag Red 54's Avatar
Jag Red 54
Sounds good, what time is dinner? John
