engine swap ideas?
Old Sep 13, 2004 | 02:57 AM
81f150351w's Avatar
81f150351w
engine swap ideas?
having questions about swapping out motor, i have a 351w that has a 30 over bore that's as much as i know about the exstint of work done . i bought the truck about a year ago it runs fine pulls good but its getting about 6-8 mpg ? and its starting to take a toll at $2.35 a gallon it has a c-6 i resently put the stock gears back in the rear end so i could use it in four wheel drive the guy i bought it from draged raced it so he put 4.11 in it . when the truck came from the factory it had a four speed manual, so all the clutch linkage is still in the cab what i was wondering what would be the best economical way to go wanting to not loose power to turn 33's and minable towing but to get better mpgs for a daily drivin rig .
Old Sep 13, 2004 | 03:28 AM
81f150351w's Avatar
81f150351w
need ideas please help
got a question about motor swap need to improve mpg and sure the best way would be to pull the stock car 351w built motor out and swap with a stock or mild build. not knowing exactly what was done to the motor other than it has been bored and dumped full of money by preveus owner. my truck has a 4 inch lift and turns 33s quit easliy now but gets -6-8 mpg has c6 and origanl linkage for the manual so i was wondering what would be a good bet for a swap trying to not spend a bunch of $ would either get a whole truck and pull the motor trans combo if eqipped W/ 4 speed or just replace the motor which leads to my question what would be a good bet for my tuck
Old Sep 13, 2004 | 04:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
You will never pay for an engine swap with fuel savings. You might check into the cam situation on the engine you have.
Old Sep 13, 2004 | 07:55 AM
jwtaylor's Avatar
jwtaylor
I agree with torque1st...what cam is currently in it? IF stock, your best bet might be to have the engine tuned by someone.
