need help with ignition switch assembly
Old Sep 12, 2004 | 11:29 PM
mopower's Avatar
mopower
My truck didnt come with any ignition key so I bought the switch and the ignition lock at autozone.Problem is I am following the instructions but I am not able to get the 2 parts to mate.anyone know if there is a trick to this?The guy at autozone wasnt able to do it either.
Old Sep 12, 2004 | 11:42 PM
Little Bro's Avatar
Little Bro
I recently replaced the switch in my '66 F250, retaining the original key and cylinder. Maybe your setup is similar to mine. Here's the instructions from my on-CD shop manual:
Insert key into cylinder. Turn key to ACC position. Place lock & key in the switch. Depress the pin (use a paper clip in the little hole on the cylinder face) slightly and turn the key counter-clockwise. Push the lock cylinder into the switch. Turn the key to check the lock cylinder operation.
Hope this helps.
Old Sep 12, 2004 | 11:44 PM
mopower's Avatar
mopower
do you need to insert the pin to get the lock in?
Old Sep 12, 2004 | 11:53 PM
Little Bro's Avatar
Little Bro
The pin is a little spring-loaded pin which you depress with a small wire, say a paper clip, by pushing on the end of the pin with your wire through the little hole on the face of the cylinder. This makes it possible for you to turn the key past that point so that the inner cylinder parts will line up with appropriate places inside the switch and thus the cylinder-key assembly will go all the way into the switch.
Old Sep 13, 2004 | 12:58 AM
mopower's Avatar
mopower
thanks for the info
Old Sep 13, 2004 | 01:00 AM
Little Bro's Avatar
Little Bro
Success, I hope. You're welcome.
Old Sep 14, 2004 | 10:08 PM
mopower's Avatar
mopower
Yea I got it in there after going to get another lock assembly as I turned it the wrong way and had all the tumblers fall out!Thanks again.
