Aerostar Ford Aerostar
Follow-up to Code 124 and code 157 problem
Old Sep 3, 2001 | 07:27 PM
chrisa's Avatar
chrisa
After clearing these codes a week ago, I checked today and code 124 (throttle position switch voltage too high) has returned. As I understand it, the TPS is a potentiometer type unit. Can anybody tell me how to check it? Is this something I can pick up at Pep Boys? The Haynes manual tells me to scribe the position of the switch onto the throttle body so it can be replaced in the same position from which it came. Does this mean that a replacement switch would have to be "set up" with a meter? If so, how?
Old Sep 3, 2001 | 10:12 PM
mwalsh's Avatar
mwalsh
had a similar problem with my '93. Before going to too much trouble try removing the rubber connector to the air plenum and spray the butterfly that the TPS connects to. I found mine was all gummed up and was holding the TPS open slightly.
If this doesn't work Autozone can give you a small booklet that describes how to test it.
Old Sep 4, 2001 | 07:12 AM
rsheltro's Avatar
rsheltro
PettitWC
Escape & Escape Hybrid
Jul 31, 2019 08:54 PM
old409
Jun 10, 2015 09:01 AM
rccr59
Sep 6, 2014 10:32 PM
PettitWC
3.0L V6
Aug 6, 2014 06:31 PM
Banjoono
Jun 5, 2014 08:58 PM
