Holley carb troubles
Old Sep 12, 2004 | 01:33 PM
sweet61's Avatar
sweet61
Unhappy Holley carb troubles
Okay, I have a Holley 2300 that won’t run under 800 RPMs and won’t run smooth till 1100 RPMs. No matter what adjustments I do the mixture is to lean. The only way to compensate is with the choke or holding down the gas pedal. The carb was recently rebuilt and the timing may not be quite right, but when we go to start it back fires out the intake and won’t start. Any suggestions will help thanks!
Old Sep 12, 2004 | 01:47 PM
cobraguy's Avatar
cobraguy
Sounds like you've blown a power valve. This is a common problem on Holley 4bbl. Blowing the power valve is caused by backfires. There are fixes but the best I've found is an Edelbrock. Oops you have a 2bbl. never mind.
Old Sep 12, 2004 | 03:47 PM
sweet61's Avatar
sweet61
i recentaly took the boul off and every thing, including the power valve was fine. But thanks
Old Sep 13, 2004 | 07:05 AM
cobraguy's Avatar
cobraguy
Check for vacuum leaks. Get it running and use some carb cleaner spray. Spray aruond the base of the carb and where there manifold meets the heads if the rpms change that is where the leak is. Also check all your vacuum lines.
Old Sep 14, 2004 | 06:39 PM
sweet61's Avatar
sweet61
thanks all
