Aerostar Ford Aerostar
A/C Cycling Pressure Switch
Old Sep 13, 2001 | 08:31 PM
Gschroer's Avatar
Gschroer
'91 Aerostar, 4.0 litre. Should there be an o-ring to seal the air conditioner freon pressure cycling switch to the valve on the dryer/receiver? I replaced the pressure switch and the new switch did not have an o-ring. The connection leaked, so I installed a small o-ring that stopped the leak, but the o-ring spread out over time and blocked the pressure sensing hole in the pressure switch.
Old Sep 14, 2001 | 01:14 PM
aerocolorado's Avatar
aerocolorado
I don't recall seeing one when I replaced the accumulator during an A/C retrofit recently. I ran some teflon tape over the threads, ran it down handtight then seated it 1/2 turn with a wrench and it sealed fine.
Old Sep 14, 2001 | 02:44 PM
mwalsh's Avatar
mwalsh
There is supposed to be an o-ring. You proably tightened the switch too much. Tighten it just a smidge (the technical term) more than hand tight.
Old Sep 16, 2001 | 08:15 AM
parkinhunter's Avatar
parkinhunter
