Voltage Issues
Old Sep 11, 2004 | 09:32 PM
MemOrex's Avatar
MemOrex
Voltage Issues
While driving, if i use the power windows, i can see my voltmeter jump down then up. At night my lights dim a little if i do that. Now is this normal? My battery IS 4+ years old... I dont remember seeing this in the past unless i wasnt looking close enough. Could i need a new alternator? New batt?
Old Sep 11, 2004 | 09:49 PM
Beast12's Avatar
Beast12
I don't think it should be a big deal. How much is it going down? Is your alternator belt tight? Check it out.
-Matt
Old Sep 12, 2004 | 11:31 PM
MemOrex's Avatar
MemOrex
It doesnt jump down that much. From like the 'M' to like the 'O'. I might just be overreacting. I'll check the alt. belt. Thanks
Old Sep 13, 2004 | 12:35 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
I would look at the battery first, clean the terminals, check the water, check the grounds. Check your fan belt. Put a volt meter on it with and without a load.
Old Sep 13, 2004 | 12:10 PM
mike L's Avatar
mike L
Clean the battery terminals, check the belts and have the electrical tested for free at autozone and maybe somewheres else if they find something wrong.
Old Sep 13, 2004 | 12:15 PM
SteveM's Avatar
SteveM
I had same problem with my 94 f-150 also my driver power window was working real slow.
After a short time of that.
I had to replace driver side power window motor.
All is ok now.
