Please help! Spongy Brakes
Old Sep 11, 2004 | 07:37 PM
94bonestocker's Avatar
94bonestocker
Angry Please help! Spongy Brakes
Here's the scoop. I have a 1985 F-150 with the 300 4.9L. It has 487,000 miles on it. I just rebuilt the motor, and the front suspension. I put a new master cylinder, rubber lines, and wheel cylinders on it. I bench bled the crap out of the master cylinder, and even ran 3 of the big bottles of brake fluid through the system. There's fresh fluid coming out when I open the bleed screws, and absoluetly no air coming out. But it's still really spongy. The pedal goes right to the floor. I have to pump the pedal to get it to stop. Like it still has fluid in the system. I'm pulling my hair out over this. Anybody have any ideas? I tried looking for a new proportioning valve for it, but I can't find anybody who sells them. The only thing left is calipers, or proportioning valve! Thanks for your help!
Old Sep 11, 2004 | 08:32 PM
dbc's Avatar
dbc
You don't mention the rear brakes....check adjustment? New master cylinder could be bad from the box. Proportioning valve possible, but not likely.
Old Sep 11, 2004 | 08:35 PM
dbc's Avatar
dbc
You don't mention the rear brakes....check adjustment? New master cylinder could be bad from the box. Proportioning valve possible, but not likely. The junkyard is the only source I have found for the proportioning valves.
Old Sep 12, 2004 | 10:31 AM
BJake86's Avatar
BJake86
Spongy brakes
Check the rear brakes for adjustment and wear. Also take a real good look at the power booster if equiped. I have an 86 with the 4.9 , replaced the calipers and master because they were shot. Got all the air out of the system but still didn't have a good pedal. Checked the rear and adjusted. Turns out the power booster was shot from sitting around. You can get that from Napa which will run you about $70 plus core. Hope this helps
