99 tranny issues
Old Sep 11, 2004 | 02:57 PM
pods8's Avatar
pods8
99 tranny issues
My 99 3.0L 76,000 is shifting slightly hard when starting to move and 1-2, the idle is around 1200 in idle. The egr is tripping a code(low flow) aswell which may or may not be related. Any thoughts.
Old Sep 11, 2004 | 06:12 PM
Vin 95's Avatar
Vin 95
A low flow cose can be caused by a clogged EGR port. when you remove the egr valve,under it is a finger sized hole in the intake.At the BOTTOM of this hole is a SMALL port that can be poked out with a stiff peice of wire. then unhook the negative battery cable for five minutes to clear the code.
Old Sep 11, 2004 | 08:26 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I would address the code before doing anything else about the idle speed/shift issue.
Old Sep 11, 2004 | 09:09 PM
Bob Ayers's Avatar
Bob Ayers
The most common cause of low EGR flow is a bad DPFE sensor...It's mounted on the upper intake (1 electrical conector and 2 rubber lines).
