Keyless Entry
Old Sep 11, 2004 | 02:44 PM
waldreps's Avatar
waldreps
Angry Keyless Entry
I've tried to follow the following steps to program a new keyless entry remote on my 1994 F150 but I can't get past step one. My truck doesn't respond. I've tried it 5 times and 8 times which I've heard works for newer vehicles. I've tried ending in run and ending in off. My truck just doesn't respond. Any ideas? My existing remote works fine, but my truck won't go into programming mode so that I can get the new one to work.
1. Insert the keys in the ignition and turn the ignition switch from OFF to RUN, five times within ten seconds, ending in RUN. If the vehicle has successfully entered the program mode, it will lock and then unlock all doors automatically.
2. Press ANY button on a keyless entry remote transmitter and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been activated. NOTE: When the first keyless entry remote transmitter is programmed, all existing keyless entry remote transmitters are erased.
3. Repeat the previous step for each transmitter that will operate the vehicle.
4. If the door locks do not respond for any keyless entry remote transmitter, wait 10 seconds and press the button again.
Old Sep 12, 2004 | 12:08 AM
Dealford's Avatar
Dealford
I vaguely remember someone having a different solution.
Search results for "Programing keyless entry":
https://www.ford-trucks.com/forums/s...earchid=287251
AL.
Old Sep 12, 2004 | 05:11 PM
Mil1ion's Avatar
Mil1ion
The link won't work because you copied a *Searched Thread*
Find it again and respond to the thread, which will bring it up to the top..
