I owe the thread an update. Got a new turbo. Running fine now. Slowly, I'm getting the "bionic truck", or the "$10M truck" because it's made up of lot of fresh new parts like the $10M man!
i have an "05" truck with 17,600 and the same noise was heard. When you let off the throttle, it sounds like the fan blade hitting the shroud or something. took it the dealer and they replaced the turbo.
"BINGO" Correct answer. Look at all of the; it's a normal sound responses and all of the turbo replaced responses fixed it. Some of you guys need to go get your truck fixed. The noise described in this thread is NOT normal for a correct functioning "air management" system on your stock 6.0. Unless you have a sticking VGT or you are over boosting (over speeding the turbine driver) the turbo with high performance parts the VGT is designed to control turbine speed and will not make the noise you are describing. Ford, Navistar designed air to flow into the motor not in and then back out of the motor when you let off the throttle. The waste gated 7.3 uses a waste gate to control turbine speed by releasing boost out the exhaust, the 6.0 VGT controls turbine speed by the electronic oil actuated opening and closing position of its vanes to control turbine speed. If the opening and closing response is operating properly like my truck does you cannot make the fan rubbing chopper sound being described here. fficeffice" /><O></O>
Some of you have mentioned that you should get the turbo change soon due to getting close to the 36k warrenty... I just got off the phone with ford and they assure me that the turbo is covered under the 100k warrenty. And they argued with me that its normal How are you convencing your dealers to install a turbo when there saying theres no problem?
From what I've seen, if there are codes, you get a new turbo. It doesn't benefit the dealership to deny real work. If you have the "need more info" code, they may want to wait. But it's not "normal"!
i guess i can assume that your talking about them hooking it up to diag. and them getting a their Rx (feedback) from the sensors. I would just need to get the truck in and ask them to hook it up and play with the throttle and see if they get a code. All i know is that it gives me an uneasy feeling everytime i hear it. So if it's not right i better do something about it.
well dang it,I thought this was normal sound,because the deisel tech at my dealer road with me and i got on the gas and let off for him to hear the whapp whapp whapp,he looks at me and said its completly normal.so should i take it some where else,i mean its running good,btw its 2006 xlt f250,with 8500 miles and the farting noise didnt start till 3k miles
New, the truck didn't wappa.
The wappa started around 24K miles.
Diag codes showed boost issues.
Dealer replaced turbo.
No more wappa.
Recap: Didn't make the noise new. Then did. Turbo replaced. Noise gone.
If the noise is normal, perhaps I should ask for my old stuck-vane turbo back! It is not normal just because a lot of them might do it. It may be familiar, but it's not supposed to happen.
Both of my turbo replacements threw NO codes. What my truck experienced was occasional lack of throttle response (loss of power) chopper rubbing sound. I inspected both bad turbos with my tech and both showed "rust" on the casting face that the vanes operate on. I have inspected several other replacements and ALL had similar "rust" on the casting. Ford has addressed the issue with a machine recessed turbo replacement along with a procedure for stroking the VGT to un-stick the vanes.
i heard this same noise on an '03 i test drove, i was in the process of burying the rear axle when i heard it. and i knew that sound is not a good one. like air was backing up in the turbo with nowhere to go. i have yet to hear it on the one i bought. so i can't say what the problem is but personally i think there is something wrong if it always does it. mine never makes the noise the one i test drove made. "knock on wood". so maybe that is why there are so many repeat turbo failures on these trucks. because the dealer thinks the sound is normal when in fact it is a broke vgt thingy he said ,that slowly kills all turbos placed on the vehicle. makes sense
The noise in itself is not the BIG problem. It is the loss of boost at low RPM that robs power, and milage.
When the noise is present there is very low boost at low RPM. At times when the turbo is working properly at low RPM there is 3-4 times the boost than when it is not.
This is evidenced by watching the guage on the dash. You can see the boost jump up at about 1500 rpm. Not rise evenly through the power curve.
Basscat has it right. Hey all of you still out there "turbo farting" down the highway. If your Ford Service says it's normal, find another FORD Service Center. Too many of us heard that story that it is normal. I suffered with it for 15K miles. Ford Service replaced the EGR as well as the turbo, now no more wa-pa-pa all the way home.
