Sponsored by: Auxito
OBDII reader
Old Sep 11, 2004 | 11:49 AM
shane7209's Avatar
shane7209
OBDII reader
anybody used one of these?
Old Sep 11, 2004 | 12:08 PM
AegisSailor's Avatar
AegisSailor
Lots of people use them. Are you asking about a paticular model or manufacture?
Old Sep 11, 2004 | 12:15 PM
shane7209's Avatar
shane7209
I saw the web site they had an it was somewhat confusing. i have a 97 f150 and would like to be able to pull the codes for eng and brakes. does this interface from the truck diag port to a computer?
Old Sep 11, 2004 | 12:16 PM
czabala's Avatar
czabala
I use a CARChIP in my 2000 f-150, it's a data logger/trouble code reader, I paid around $90.00, Sears hardware has them for $50.00.
Old Sep 11, 2004 | 12:25 PM
shane7209's Avatar
shane7209
Thanks guys, will this pull abs codes also
Old Sep 11, 2004 | 03:01 PM
AegisSailor
I'm not sure. The ABS system gives you the fault codes by flashing the ABS light, I don't know if it also reports the codes through OBDII.
Old Sep 11, 2004 | 08:49 PM
Racerguy's Avatar
Racerguy
The ABS does send codes to the DCL connector but it seems that most consumer type scanners wont read them. Ones made for techs, such as at http://www.diagtek.com/index.shtml, can usually pull powertrain, body and chassis codes.
If you can find a website for the scanner your looking at it should tell you if it can read ABS codes.
Old Sep 11, 2004 | 09:31 PM
wmcnally's Avatar
wmcnally
shane7209,
I have a '98 4.6L. The '98 and '97 trucks have the analog gauges. I always wished I had the Digital display with speed, coolant temp, RPM and MPG as reported to the ECU by the various sensors. I found a product with ALL this and it's an OBDII code reader too! I bought it for $100.00. I've installed it and am very impressed. Check it out:
http://www.scanguage.com/
I don't know if it will read the ABS codes or not. Perhaps you can e-mail them and ask.
