Which rear End do i have?
Old Sep 10, 2004 | 04:05 PM
72ford360's Avatar
72ford360
Hello all i have a 73 f100 came with a v6 1 barrel im not sure if i have a ford 9' rear end can some one help the vin on the truck is F10ARS05766 any help is appreciated thanx
Old Sep 10, 2004 | 10:25 PM
Phinxter's Avatar
Phinxter
If you dont have a removable rear diff pan it is a 9"
The possiblity of the problem being the Rear Axle Housing Vent Tube is highly unlikely.
(Funtest,name that part answer, Dennis)
Old Sep 11, 2004 | 01:24 AM
72ford360's Avatar
72ford360
would you know how many splines are on the axles?? we want to buy a centersection and just drop it in would that be much work??would it be just a matter of droping in the axles ???any ideas or comments would be great as i am only 18.thanx
Old Sep 11, 2004 | 02:35 AM
85e150's Avatar
85e150
You probably have 31 spline axles. Pulling the center section is fairly easy, made much easier if you have a good place to work on it.
I'd pull it and go shopping. Have them swap your yoke over to the new one if you buy a rebuild. Or have yours redone.
Clean out your axle housing, esp if yours is a growler or broken.
Don't forget the axle tubes when cleaning.
