Possible wheel bering problem??
Old Sep 9, 2004 | 07:36 PM
nativemtn's Avatar
nativemtn
Question Possible wheel bering problem??
I have a 97 4X4 Explorer, recently purchased, the left front seems to have a bit of a bump when driving.
How do I check for possible Bering problems?
Old Sep 10, 2004 | 09:38 AM
LOTR-HAMMER's Avatar
LOTR-HAMMER
first maybe try changing the tires around put the tire where the problem is on the rear to see if it makes a difference. If its still bumpin then maybe you do have a bearing problem. You will have to pull it apart to get to the bearings.
pull the tire off pull the caliper off take off the hub and unscrew the big nut in the centre of the axel excetera excetera excetera a hanes shop manual will help you a lot
good luck
Old Sep 29, 2004 | 11:46 AM
mmlco's Avatar
mmlco
If this is a sealed unit wheel bearing/hub like my 97 AWD, then you'll need to jack up the truck and have someone grasp the tire and try to rock it back/forth; you would be able to see some play as the wheel bearing/hub spearates from the spindle. Also, once you get the rotor off you may see grease all over the wheel bearing/hub. Good luck.
