Hi Guys,
I put a 4" lift on my 1994 F-150 and had the alignment done. However I had 31" tires on it at the time, now the truck is sitting on 33" x 12.50" Mud Terains on 10 in. rims and it appears to be toe out just a little. Am I correct in assuming tire size does not matter when having alignment done? The truck does not really pull either way.
I believe you are right. Whenever you start fooling with the suspension height with a lift or drop it affects the camber. If the Truck has a tendency to pull on either side with new tires, I would swap the two front tires and see if the truck still pulls and go from there. The only way to be definate about toe is to have the truck aligned again to see if you have to adjust the tie-rods. good luck
