Timing + Belt Tensioner
92 E-350 7.3L IDI
straight to the point, i have two questions:
1. Is this a timing problem?; the past week i've noticed a slight, low-pitched knock for about two seconds when i accelerate from idle, kinda like when a motor is "dieseling" or stalling out, and it's been getting more frequent (everytime i accelerate). I've also noticed it's not running as smooth as when i first got it, dark smoke comes out on random accelerations, and it's randomly harder to start than other times. The change happened when a very questionable mechanic swapped out the IP, this guy was truly a dolt, he left a few things loose and was in a hurry. Thats why i suspect something related to the IP. -NOTE-i have checked all the fuel lines for leaks, and the air/fuel filters are on tight.
2. Do i need a new belt tensioner?; my belt tensioner is bouncing up and down a bit causing the belt to "chirp" on the pulleys (all the pulleys "seem" fine, i don't see any of them wobbling or not wanting to turn)
Thanks for any of your wisdom you can share, i'm so thankfull for these forums!!
Last edited by dieselcanuck; Sep 8, 2004 at 10:17 PM. Reason: needed to add engine model
this problem was causing the motor to run rough and tug on the belt tensioner creating belt slippage.
replaced the injector, runs like a champ.........
i'm still getting a little unburt fuel coming out the exhaust, i hope i tightened the injector down properly (didn't use torque wrench, just tightened to snug). i'll do another injector test and see if any other injectors are acting up........
