4 speed OD linkage difficulty
Old Sep 8, 2004 | 07:49 PM
kookiewad's Avatar
kookiewad
upon reinstallation of the tremec manual 4 speed overdrive trans in my '78 f150 xlt supercab i can't seem to get the linkage to operate. is there a trick to setting it up, like having it in a particular gear? thanks...
Old Sep 13, 2004 | 01:07 AM
inliner's Avatar
inliner
You need to loosen the linkage adjustment nuts so there is plenty of slack, then move the tranny tabs so that the trans is in neutral, then place a 1/4" drill bit into the alignment hole in the shifter mechanism, it's just below the pivot point of the shifter. After the holes are all lined up with the drill bit you can tighten up the adjusting nuts and remove the drill bit.
Old Sep 13, 2004 | 09:51 AM
kookiewad's Avatar
kookiewad
thanks very much. i actually got it without the bit after messing with it for a while
Dylan518
Aug 18, 2020 08:56 AM
pugetsoundsailer
Jul 30, 2016 10:43 PM
Trey_Morgan
Jun 15, 2013 05:51 AM
ford7872
Jan 27, 2013 03:33 PM
Dirrttym
Nov 1, 2012 02:59 PM
