water drain plug (where)
Old Sep 7, 2004 | 09:59 PM
tsheriff's Avatar
tsheriff
can some one please tell me where this thing is. a frind and i crawled under both our trucks and throught the engine compartment looking for it.
Old Sep 7, 2004 | 10:19 PM
johnsdiesel's Avatar
johnsdiesel
ON EDIT: Sorry, wrong pic. I thought I found a pic for you but it was a link to something else.
Old Sep 7, 2004 | 10:25 PM
npccpartsman's Avatar
npccpartsman
It's directly under the drivers side door on the inside of the frame rail--takes a 6mm allen wrench--be very careful not to strip the hex or you'll be at the dealer getting the warranty work done
Old Sep 7, 2004 | 11:53 PM
PowerStroke King's Avatar
PowerStroke King
Partsman gave you the correct location. When you open the drain, you don't need to drain it for more than about 30 seconds at the most. I believe it holds about 100cc's of water.
You should have received a 6.0L Powerstroke booklet with your purchase. It has a diagram and explanation on draining the fuel-water separator, as well as how to change the filter on the left end of the device.
Old Sep 8, 2004 | 05:51 AM
SBV45's Avatar
SBV45
Look at the diagram here http://home.austin.rr.com/sbv1/Proce...ater-drain.htm
Old Sep 8, 2004 | 12:22 PM
FordRuss's Avatar
FordRuss
Originally Posted by SBV45
Thanks for posting the diagram, SBV45
Russ
Old Sep 8, 2004 | 06:46 PM
mikeyG9's Avatar
mikeyG9
FYI - I'm going in for warranty work tomorrow for the plug stripping. Not totally yet but close enough. The dealer said they have a fix that replaces a lower part of the housing w/plug. Should take a couple of hours. Don't know how they can replace only part of the housing but...
And if you haven't already, get a 36mm socket for the fuel and oil filter caps. Can easily over/under tighten with a band wrench, etc.
Mike
Old Sep 8, 2004 | 06:50 PM
Daryl Hunter's Avatar
Daryl Hunter
And watch the torque on the 36 mm oil filter nut too. Don't know why they decided to use such a big nut as folks might be tempted to over torque it based on it being such a large sized socket.
A 19 mm nut would have been just fine for that torque.
Old Sep 8, 2004 | 07:39 PM
Frobozz's Avatar
Frobozz
The water separation manifold (in whose cover plate the drain plug is located) is a little section bolted onto the side of the main HFCM housing. So it's actually kind of handy when the hex hole strips to just replace that unit. And for early trucks, they're likely to *want* to do that anyway, since there was a TSB out about the water in fuel sensor (inside that manifold) getting crudded up and sticking "on" on early trucks.
Duncan
