General Automotive Discussion
what cam is this? (specs inside)
Old Sep 7, 2004 | 07:28 PM
84f150guy's Avatar
84f150guy
the chart says..
specs @ .050 camlift sae
opens closes duration opens closes duration
int 0 tdc 34 abc 214 34 btc 78 abc 292
exh 49 bdc 5 btc 224 83 bbc 39 atc 302
cam lift gross valve lift center line c/l rocker arm ratio valve lash clr
int .295 .510 107 1.73 hyd
exh .310 .536 117 1.73 hyd
everything without a "." is degrees
any help would be appreciated. someone asked me what kind of cam was it in it, and i had no idea. thing idles at like 600 though.
