1978 - 1996 Big Bronco
3rd Tranny
Old Sep 7, 2004 | 03:44 PM
dyarumian's Avatar
dyarumian
3rd Tranny
last winter i lost first and second gear. and i got a used tranny droped in $1,700 latter it drove good untill i lost 5th and reverse last week. now the mechanic is sawing hes gonna have to open it up the see whats wrong this time. But now its over the 6 month warrenty so i might be SOL. Not too happy with this. I figured a $1,700 tranny would outlast my truck. Anyone have a mazda or even better ZF tranny they want to give me?
Old Sep 7, 2004 | 04:11 PM
Jdenninger's Avatar
Jdenninger
sorry, all I have is an 89 AOD
Old Sep 8, 2004 | 10:48 AM
Kemicalburns's Avatar
Kemicalburns
what tranny is in there now is it the m5od or the zf? i would scream bloody murder to the guy that rebuilt that tranny to begin with. there is no reason for a manual to go out like that unless your playing real real hard on it.
Old Sep 8, 2004 | 10:42 PM
dyarumian's Avatar
dyarumian
its the m5od. i would upgrade to the zf if i could afford it but in in the colledge kid budget and i will be wiped out prety bad as it is.
Old Sep 9, 2004 | 12:21 AM
JBronco's Avatar
JBronco
Manual trannys rarely break, and especially not three times, unless they were put together wrong in the first place or you are pulling the Queen Mary with it.
Old Sep 9, 2004 | 01:10 AM
93BigBlackBronco's Avatar
93BigBlackBronco
Mazda trannys are known for shifter rail seal failing. No drips(seals on the top) but eventually all fluid leaks out and your tranny is done. My old truck did this, after rebuild mechanic used softplugs instead of rubber plugs. Ask you mechanic.
Old Sep 9, 2004 | 08:59 AM
Kemicalburns
i must say that tranny is not a good one. ford messed up by droping that into these heavy rigs. plus your running stock gears with a 32" tire so that wont help either. I would start searching for a zf in some of your local wrecking yards and also find another mechanic because he has found himself a sugar daddy.... YOU!
late
Old Sep 10, 2004 | 07:37 AM
dyarumian's Avatar
dyarumian
will the ZF bolt right up?
Old Sep 10, 2004 | 09:10 AM
Kemicalburns
Yes, it was an option i believe. do a search it has been coverd many times in this forum and some others that cant be named lol
