'71 trailer wiring
Old Sep 7, 2004 | 11:05 AM
towrig302's Avatar
towrig302
'71 trailer wiring
Anyone make a fancy trailer wire adapter, or do I cut & splice? Thanks
Old Sep 7, 2004 | 12:52 PM
Franklin2's Avatar
Franklin2
Cut and splice. I can't find anything. Solder the connections and they will last a long time.
Old Sep 9, 2004 | 10:20 AM
ms_michelle's Avatar
ms_michelle
Red face
I had a 72 F-250 camper special and it had a plug in connection about half way between the back of the cab and the rear axle, along the left frame rail. Check to see if your truck has this connection, if so it will save you lots of time. The connector contained brake/turn, tail, back up, ground, and a constant 12V lead for inside lighting.
Michelle
Chelle's 56 Hauler
Old Sep 9, 2004 | 01:26 PM
76supercab2's Avatar
76supercab2
On my last trip to the salvage yard, I chopped a harness connector from the tailight harness of a truck same as my year. My intention is to make an adapter by taking the male and female parts of the harness, soldering the wires to each other along with the trailer harness, then plug this into the truck's wiring.
