Sponsored by: Auxito
1998 Temp Guage
Old Sep 7, 2004 | 10:33 AM
TX Paul's Avatar
TX Paul
1998 Temp Guage
I have a 1998 F-150 and the temp guage sometimes flips back and forth from normal temp to Hot. The movement is not slow but very quick and it goes back to normal just as fast. It is usually when at idle and then when I accelerate it goes back to normal. Sometimes it acts up while driving. I have replaced the sensor and I know it is not heating up. It is someting else. Please help. Thanks
Old Sep 7, 2004 | 08:32 PM
Racerguy's Avatar
Racerguy
Hi Paul and welcome to the forum
What size engine do you have in your truck?
Old Sep 8, 2004 | 09:16 AM
TX Paul's Avatar
TX Paul
It is the 4.6 V8. I only replaced 1 temp sensor. I am told by someone else that there are 2 sensors. Is that right? Could that be the problem?
Old Sep 8, 2004 | 09:32 AM
Racerguy's Avatar
Racerguy
There is the ECT (Engine Coolant Temperature) sensor that tells the PCM how hot the engine is and then there is the sender for the temperature gauge.
Both are in the front of the intake manifold. The sender for the gauge should be the closest to the thermostat.
Old Sep 8, 2004 | 09:40 AM
TX Paul's Avatar
TX Paul
I must have replaced the ECT. The other sensor on the same wire loop was close to the thermostat. I guess I need to replace that one also.
Old Sep 8, 2004 | 08:26 PM
Racerguy's Avatar
Racerguy
Let us know how you make out.
Old Sep 27, 2004 | 03:04 PM
TX Paul's Avatar
TX Paul
I have replaced both sensors. It is better but not fixed. The guage still dances around. I do not know what else it could be except the guage. PLEASE NO! I don't want to have to replace the whole instrument cluster. Any more ideas?
Old Sep 27, 2004 | 04:02 PM
PaulC's Avatar
PaulC
Air pocket in cooling system?
Old Sep 27, 2004 | 07:03 PM
Racerguy's Avatar
Racerguy
I would find someone with a good scan tool that can monitor the ECT to see what the temperature is really doing. If it is staying steady but the gauge is jumping around then you probably do have a gauge problem.
