Transmission swaps???
I have a 93 explorer 4wd. My tranny just started acting up by not going into reverse or overdrive. Is there an easy fix for this? If not, I was considering swapping out the A4LD for a better tranny. Can someone give me an idea of what tranny would work best. I want to keep the 4.0 V6. Also there's a site that I ran into with the Raptor "700R4" transmission. Are these reputable?
thx
Yes, it's a slow-thinking tranny and it has no electronic brains. But this is pretty reliable thing, I am sure. And pretty nice working, too.
So if you want to minimize your loss, try to rebuild yours or swap it with remanufactured A4LD. This should be much cheaper than adopting other tranny to your truck. Also you must be aware that you probabaly will need to replace the torque converter in any case.
With best regards,
Yuri
Van
