Losing Boost Under Full Throttle?
Old Sep 6, 2004 | 10:23 PM
A355ONGAS's Avatar
A355ONGAS
Cool Losing Boost Under Full Throttle?
I have a 2000 excursion with a 7.3 . My micro tuner is the only mod. Under heavy accerlation the truck is fine until i hit 17 pounds of boost and then its sounds like the rest is getting blown off. I started haveing this problem about 3 weeks after I installed the tuner. When I install the stock tune this problem goes away. Was wondering what ya'll think?
Old Sep 6, 2004 | 10:26 PM
Kwikkordead's Avatar
Kwikkordead
Turbo compressor stall. Suggest doing a search on that subject. Grab a favorite refreshment and get ready to read a lot.
Old Sep 6, 2004 | 10:27 PM
A355ONGAS's Avatar
A355ONGAS
but what is a fix?
Old Sep 6, 2004 | 10:40 PM
Kwikkordead
Originally Posted by A355ONGAS
but what is a fix?
The most common fix is the Wicked Wheel and ATS ported intake housing.
Old Sep 6, 2004 | 10:43 PM
A355ONGAS's Avatar
A355ONGAS
I thought it was to do with the wast gate because it sounds like a big hiss sound. One of my friends at the ford dealer was going to waranty a whole turbo.
Old Sep 6, 2004 | 10:56 PM
wlihntr's Avatar
wlihntr
you may be losing boost through one of the intercooler tube (the silver tubes on either side of the engine) boots. there are 4 of them(8 clamps) it is somewhat common for one or more of them to get loose and vent pressure out of them. make sure they all all tight. if you see any oily residue near any of them that is a dead give away it is leaking, just tighten them down real good and that should fix it(if that is the problem)
Old Sep 6, 2004 | 10:57 PM
Kwikkordead
No, it's a common problem with modified PSD engines. The stock turbo cannot keep up with the demand and all the pressure rushes back out of the intake housing. It least that's what I have been able to gather from reading here on the forum. If you leave it on a stock tune or at most a mild tune and you're ok.
Old Sep 6, 2004 | 11:01 PM
A355ONGAS's Avatar
A355ONGAS
so if i install a wicked wheel, housing and big head it should be able to handle the boost?
Old Sep 6, 2004 | 11:03 PM
A355ONGAS's Avatar
A355ONGAS
I have noticed that where the clamps are its getting dirty so ill pull them off, clean and tighten them to see if it fixs it
Old Sep 6, 2004 | 11:23 PM
fordnut74's Avatar
fordnut74
May just be the factory wastegate doing what it is designed to do. Try removing the red boost tube going to the wastegate and stuff it on the one of the clamp bolts nearby. With the clamp mod and a bypassed wastegate I CAN go all the way up to about 28 psi, but seldom do.
Old Sep 7, 2004 | 02:58 AM
Quadzilla's Avatar
Quadzilla
Since you're venting boost at a relatively low boost level, 17, I'd suspect you've got a leak at a fitting. The wastegate shouldn't be blowing off boost until you're considerably higher.
