Installing the rubber bumper strips in my new gate today. I was at a show just now and saw them installed both ways. Now I am wondering if I had them right last time. Does the rounded part face inboard or outboard?
Dewayne, I was just answering the tailgate latch question and noted the lack of tailgate rubber bumpers on most trucks. I have tried these bumpers in every direction and have decided that the rounded portion should face the bedside. Otherwise, when the tailgate is closed, thebedsides are pulled in too far and past verticle. Does your gate have the little finger tabs on the outside edge? These will hold the rubbers just right once you press them in. Good luck, John
The strips go in each side where the gate hits the bedsides. Just below the latches. You will notice two triangular punches in your gate on each side. You bend the tabs and they hold the strips in place. They usually get hard as a rock. If you don't use them you would surely have a rattle with the stock chain type latch. Not to mention paint loss.
