Aerostar Ford Aerostar
Changing Dash Lites
Old Apr 15, 2002 | 08:30 AM
tomucen's Avatar
tomucen
Changing Dash Lites
Old Apr 16, 2002 | 07:46 AM
Vike's Avatar
Vike
Post Changing Dash Lites
I have a 1993 Aero that is slowly going dark on the dash. I haven't figured out what the easiest way to get to all those dash lites and replace them would be. Has anyone had experience with this and how to go about it? thanks, Rick
Old Apr 16, 2002 | 03:20 PM
aerocolorado's Avatar
aerocolorado
Changing Dash Lites
Mine is a 91 and accessing the dash panel is fairly easy. Remove the top cover, unscrew the dash panel and tip forward to change the lamps. I'm not familiar with the newer dash designs after 92, such as yours. At the risk of sounding condescending, did you check the rheostat switch that controls the intensity of the panel lights? Often it gets bumped or moved by accident from inexperienced drivers searching for other control *****. Some of the other regular posters with the newer designs can hopefully help you out.
