Larger rims
17's and up may be fine for a boulevard cruiser, but for those of us that want to have a good set of aftermarket tyres fitted for off-road/highway use, I am unable to find any, and even if I did I am sure the cost would be horrendus.
What do you guys think about this trend for larger rims, and lower profile tyres?
People want better brakes with heavy vehicles so the rotors get larger and the rims must grow also to fit around them.
The tire manufacturesrs will be offering larger tires in all kinds of styles if demand for them is there. Keep looking, I have seen very large tires on large rims around.
I understand braking performance is important, but there are many other ways to improve braking performance without increasing rotor size.
As for large tyres, all I want is some tyres that are the same size as OE tyres, just tyres that provide better traction on dirt roads, I have no need for larger tyres (I tow quite a lot), and it is very difficult here in Oz to get abnormal tyre sizes, It may be fine in the States where around 200-300 thousand Superduties are sold each year, here in Australia they sell around 1000-1500 per year, and I doubt any tyre manufacturer (other than the OE manufacturer) would import a tyre with such small sales expected...
There are things like improving friction materials and clamping force but the biggest improvements for brakes come with leverage (rotor dia) and swept area. Therefore you get bigger rotors.
As for the increasing brake rotor diameter, there is only so wide they can make the braking surface due to hub diameter and wheel diameter and the only way to get more braking power is to have greater swept area, which means 2 things: increase the rotor diameter (and therefore the total area of rotor contact surface) and increase the size of the pads. Since the trucks are 4-wheel disc, they don't have the option of going to wider rear drums to increase braking power anymore like they used to.
Now a couple more questions.
What about snow/mud chains on low profile tyres?
They are quite likely to damage the rims aren't they?
Also "kerbing" would be more of an issue, this is far more common with low profile tyres, I know you can put wider tyres on, but still you aren't able to put as wide a tyre on when they are lower in profile...
To improve braking performance with smaller rotors maybe I will have to order my next truck with the ceramic brake option...
As far as tire chains go you may have to test fit some of them and even add links for the side chains to keep it away from the wheels. I have several sets of chains that have not seen the light of day for 20 years.
