carb problem
Old Sep 5, 2004 | 10:43 PM
72ford360's Avatar
72ford360
carb problem
1406 carb problem
<HR style="COLOR: #666666" SIZE=1><!-- / icon and title --><!-- message -->my friend has an Edelbrock 600 cfm 1406 carb the problem is that is throwing too much fuel into the throttle blades fro the venturis.my Holley dp 750 had done that before and it was the float bowl being too high i have nio idea how to mess with an edelbrock and need your help do u guys think its the float bowl if it is how would you adjust on an edelbrock? my friends that says its the fuel pump but its a stocker mechanical fuel pump could it be the problem though?? any help would be greatly appreciated .thanxs in advance
Old Sep 6, 2004 | 12:41 AM
Big Dave's Avatar
Big Dave
Smile Here is the manual
The float adjustment is made by removing the top of the carb (airhorn assembly) and taking measurements. Here is a link to the manual for that carb on Edelbrock's webpage.
http://www.edelbrock.com/automotive/index.html
Click on the carburetors link, then on EPS carb manifold link.
If it is a new carb, they reccommend doing this right out of the box to ensure the float adjustment didn't get messed up during shipping.
Hope this helps,
Dave
Old Sep 6, 2004 | 12:46 AM
zekes66's Avatar
zekes66
I could be wrong here but, could the acclerator pump need adjusting. You can adjust them on Edelbrocks in the front of the carb. There is a small "plunger" with a lever attached, if you move the rod the moves the lever down(there is 3 holes) you will get less gas when you first stomp on it.
