Aerostar Ford Aerostar
Problems Starting
Old Sep 5, 2004 | 09:24 PM
donaldson202's Avatar
donaldson202
Problems Starting
I have a 1991 extended van with a 3L engine. Some times it starts up fine but others it will take me 30 minutes to get it started. It seems to turn over fine; the idle speed seems low when you initially start it. Before its warmed up when you press on the accelerator pedal the engine wants to bog out. When this situation first began it would only be hard to start when it was warm it always started after sitting, now it’s all the time I replaced the spark plugs, wires, distributor, and rotor. Cleaned the throttle body and replaced the fuel filter nothing helped. I also have a couple of other problems maybe someone can help me with trouble shooting the AC and cruise control do not work at all and it loses anti freeze about a quart a day it will sometimes smoke (white) when I get it started. Thanks in advance.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Sep 5, 2004 | 09:57 PM
Beast12's Avatar
Beast12
Well the losing coolant is linked to the white smoke on start up. You probably don't want to hear this but you are probably looking at a new head gasket. That could also link to your van not running right either. Good luck!
-Matt
bkuuz1
May 2, 2014 09:47 AM
ikaro
Nov 27, 2013 01:07 PM
mmjax25
1997 - 2003 F150
Apr 21, 2008 07:17 AM
