Aerostar Ford Aerostar
Speed sensor 89 3L
Old Apr 29, 2002 | 07:49 PM
PWK's Avatar
PWK
Post Speed sensor 89 3L
Where is the speed sensor that senses for the computer that controls shifting on the tranny? How do you test it and is it easy to replace?
I continue to overdrive problems and this is the last item that has be recommended to check so I thought I'd just replace it if it's not to expensive and see the results. Only problem is I don't know where it is or what it looks like.
Thanks
Old May 4, 2002 | 10:59 PM
crazy500's Avatar
crazy500
Speed sensor 89 3L
i drive an 87 ford aerostar so i am assuming it would be the same. Just pull the fuse sor the one that says spd cont. it will also take out back wiper blades and rear defroster.
Old May 6, 2002 | 09:58 AM
bfalcon's Avatar
bfalcon
Speed sensor 89 3L
Shanemh
Feb 24, 2012 09:41 AM
ErrorS
1978 - 1996 Big Bronco
May 13, 2011 08:51 PM
mullinsmn
Nov 29, 2006 09:53 PM
flgal
Sep 20, 2002 12:35 PM
