PIP code and not running?? Need help boys.
Old Sep 5, 2004 | 08:48 PM
djhuebner's Avatar
djhuebner
My sons 94 f150 truck (5.0L eng) started fine a while ago but shortly after he drove away it died. All electrical systemslike lights, accessories, etc appear to work. It' raining pretty hard so I haven't actually tested the spark yet.
I scanned the computer and got a 211 code for PIP circuit failure. What is a PIP and where is it located on the engine? Could this thing have become unplugged or is it likely that it needs replaced?
I appreciate your help,
Don
Old Sep 6, 2004 | 07:39 AM
95 F150's Avatar
95 F150
One thing you can check out is make sure all the electrical connectors are plugged in good. I accidently unplugged my PIP sensor one time and I got the same check engine code #211, I reconnected the plug in connector and all was well, the plug in for the PIP sensor is located on the drivers side fenderwell under the hood, it's up close to the cab toward the top of the engine compartment.
Old Sep 6, 2004 | 07:21 PM
EPNCSU2006's Avatar
EPNCSU2006
The PIP is the timing pickup in the distributor. Check the wiring connections, and have the TFI module tested.
Old Sep 7, 2004 | 12:33 PM
djhuebner's Avatar
djhuebner
It was the pickup coil in the distributor.
Thanks,
Don
