1406 carb problem
Old Sep 5, 2004 | 05:23 PM
72ford360's Avatar
72ford360
1406 carb problem
my friend has an edelbrock 600 cfm 1406 carb the problem is that is throwing too much fuel into the throttle blades fro the venturis.my holley dp 750 had done that before and it was the float bowl being too high i have nio idea how to mess with an edelbrock and need your help do u guys think its the float bowl if it is how would you adjust on an edelbrock? my friends that says its the fuel pump but its a stocker mechanical fuel pump could it be the problem though?? any help would be greatly appreciated .thanxs in advance
Old Sep 5, 2004 | 11:21 PM
matt77F2504x4's Avatar
matt77F2504x4
those stock mech. fuel pumps can fail and increase fuel pressure, i dont know if that's your problem but mine failed and caused me to run rich.
when you replace it, if it's on a v8, then the top bolt will give you trouble. use a deep 1/2" socket and you should be able to get it.(my rebuilders left it loose!)
Old Sep 6, 2004 | 01:49 PM
LxMan1's Avatar
LxMan1
It could have some debris in the needle and seats. Remove the top of the carb. Turn it upside down and using a 9/32" drillbit, check the gap between the top and the floats.
