i have 97ranger 2.3 and my a.c. onlyworks on max the temp. switch i doesnt work either i guess when i turn the a.c. on normal the comp. is still running ,but the heater kicks in at the same time . the defrost is heat only . i have looked at all the vac. hoses they are all connected and not kinked the door opens under the dash when switching from max to normal on max it cools to 42 degres anyhelp much apprecated.
thanks
justin
and one more thing does anyone else have a problem looking at the 2.3 timming belt in the sticky thread ??????
Look at the "blend door" fix in the tech info thread, you have a broken blend door and it's stuck on heat. The MAXAC setting turns off coolant flow to the heater core, thats why you get cold air in that setting.
I checked the seventh link from the top "2.3L Timing belt" and it worked OK. If your still having a problem I can email the document to you.
i cant look right now on the blend door but i will just as soon frances passes over we are getting a our first band now i live right in the border of apopka and ocoee all and we are board up here ,
but the 7th link down is the one i am tring to access if you can email me that would be awsome justinsinternet@yahoo.com
