Cruise control
Old Sep 4, 2004 | 02:31 PM
cjnel99's Avatar
cjnel99
Cruise control
I have a 1978 Camper Special. My grandfather bought it new and passed it on to me about ten years ago. He had installed an aftermarket cruise control on it and now the vacuum servo is bad because the rubber seal is cracked. There is no identification on the unit so I can't look up the company to see about a replacement part. Everything else works fine so I don't want to replace the whole unit. Does anyone know where I can find generic aftermarket servo without buying an entire unit?
Old Sep 4, 2004 | 05:19 PM
76supercab2's Avatar
76supercab2
Without knowing the brand, I'm not sure the wiring would cross over. I'm not aware of any generic servos. I would probably just buy a whole new system.
Old Sep 4, 2004 | 07:06 PM
cjnel99's Avatar
cjnel99
There is no wiring on the unit. It just has a vacuum connection in the back and a spring inside that pushes against a rubber cover that has the chain that hooks up to the throttle linkage. I thought that this device was the servo.
Old Sep 4, 2004 | 08:56 PM
76supercab2
Yes, that is the servo. But there has to be something that modulates the vacuum. I thought on my Ford factory servo there were some wires from the brain box that connected to the servo.
Thinking about it you might check in the junkyards for a gm with cruise. I seem to remember that they were like this. Even if you can't get a good used one, you could get a new one for the make/model you found a matching unit on.
Old Sep 5, 2004 | 08:51 AM
cjnel99's Avatar
cjnel99
Thanks. I'll see what I can find. Worst case I'll have to spend $150-200 for a new unit.
Old Sep 5, 2004 | 11:34 PM
beaver77's Avatar
beaver77
Jc whitney has complete systems, I bought one from them it is made by audiovox its all electronic, it works great on my 77 4by4. It was only 115 dollars.
Old Sep 12, 2004 | 11:19 PM
good 'ol ford's Avatar
good 'ol ford
the audiovox unit is great if u want to get somthing new. its fairly easy to instal just make sure u get the magnetic sensor and pickup done with the right clearance (trust me on that one). other wise for 110 its a really good deal.
Old Sep 16, 2004 | 08:29 AM
cjnel99's Avatar
cjnel99
I used some RTV and plugged the holes. It's working like a champ now. Thanks for the responses.
Old Sep 18, 2004 | 08:27 PM
John Thomas II's Avatar
John Thomas II
I just bought an audiovox cruise control for my '77 truck. I cannot get it to hold speed. Maybe you can help me out.
1. Where did you set your DIP switches?
2. Did you use the magnet?
3. Where did you hook the blue tach wire?
4. Where did you hook the vacuum line?
I hooked everything up according to the manual, but it is not working.
Thanks a lot,
John Thomas
jntmjt1@sbcglobal.net
