1993 E150 Technical Data
Old Sep 4, 2004 | 03:32 AM
Norvian's Avatar
Norvian
Hi People
Here in the UK <ST1</ST1it seems impossible to get reliable technical data on my E150. In desperation I ordered a Chilton repair manual but that's completely useless, as expected!<O</O
<O
Can anyone recommend a workshop manual or can anyone help with the following info?<O</O
What is the total refrigerant capacity and the maximum and minimum pressures for the A/C? It is also fitted with an additional evaporator at the rear of the vehicle.<O</O
Also the front wheel alignment angles…toe, camber and castor? I have a problem with the vehicle crabbing at speed when it hits the slip stream of large vehicles especially trucks. The van appears to have excessive negative camber, which could be causing the problem but I would like to confirm.<O</O
Old Sep 4, 2004 | 12:47 PM
walkinez's Avatar
walkinez
Hello,
I've gotten regular Ford Service Manuals on E-bay, for a decent price.
The full charge of R-12 with the rear unit is 4.75 lbs.
Hope this helps with some of it.
Cheers, Bob
Old Sep 4, 2004 | 02:30 PM
Norvian's Avatar
Norvian
Thanks for the help and advice Bob. E-bay hadn't crossed my mind for some reason, I will give it a try.
Cheers
Norman
Old Sep 4, 2004 | 02:40 PM
Cor's Avatar
Cor
Hi Norvian,
Know the feeling, but we did know what we started off didn't we?
Please see a thread about caster/camber, which I startet off and very useful answers.
Hope this is of some help
Cor
Old Sep 5, 2004 | 01:01 AM
Norvian's Avatar
Norvian
Hi Cor
Thanks for the pointer. That thread looks very interesting, quite a lot of information to digest.
Cheers
Norman
MPD56
6.7L Power Stroke Diesel
1192
Oct 31, 2024 04:40 PM
Big-Sarge
47
Jan 17, 2024 10:32 PM
TexinCali
May 27, 2018 02:43 PM
Truckandute
Aug 28, 2014 01:42 PM
LAbronc
1978 - 1996 Big Bronco
May 22, 2014 10:15 AM
