Aerostar Ford Aerostar
90 Aerostar problem
Old Jun 28, 2002 | 02:50 PM
az_medic228's Avatar
az_medic228
90 Aerostar problem
I live in a very hot climate in Arizona, ( temps are about 110 degrees in the day) and have a problem of the van dying after it is run for a while. This is usually after running it for about 50 to 100 miles the van just shuts off, and sometimes will start, but there is no power. I have ran the codes, and it keeps giving me a code 11(OK) Once the van sits for a hour or so, it will start and run fine. I am thinking that maybe the TFI module is going out. I am going to take it out and run it to get checked. I had to replace the engine last year, and since then, it has had this problem. I noticed that the wrap around the fuel lines was not replaced, could this also have an effect on it? Any suggestions would be appreciated.
Rod
90 Aerostar
88 Bronco2
85 F250 ext cab
Old Jun 28, 2002 | 08:25 PM
rjcline's Avatar
rjcline
90 Aerostar problem
