General Automotive Discussion
New Ranger engine
Old Sep 2, 2004 | 10:48 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
New Ranger engine
New ranger engine???
http://www.nav-international.com.br/...?Idioma=2&Id=1
I think so....
Old Sep 3, 2004 | 12:29 AM
BigF350's Avatar
BigF350
FTE Emeritus
And from the same site:
How about this in an F150
http://www.nav-international.com.br/...Idioma=2&Id=12
What so you think?
Old Sep 3, 2004 | 03:13 AM
AlfredB1979's Avatar
AlfredB1979
I think so....
I hope so.
I can't stand the thought of owning a SuperCab Ranger now since they only come in v6 form (I'm not a big fan of the 3.slow or those 4.0 timing chains and their related issues) and they haven't made a 4 cylinder 4x4 SuperCab since the mid 80s!
Old Sep 3, 2004 | 06:50 AM
jroehl's Avatar
jroehl
http://www.nav-international.com.br/Motores.asp?Idioma=2&Id=12
What so you think?
Doubtful. If you look at the specs, you'll see that the dry weight of the engine is 422kg, which is about 930lbs. That's a pretty heavy engine for the light front suspension of a half-ton. I could see it as a fuel-efficient base engine for a 3/4-ton truck, though.
Jason
Old Sep 3, 2004 | 12:21 PM
MustangGT221's Avatar
MustangGT221
Something's gotta be wrong with that weight figure, 930 lbs is a huge engine, small block V-8s are around 500-600 lbs.
Old Sep 3, 2004 | 04:55 PM
BigF350's Avatar
BigF350
FTE Emeritus
Good pick up, I didn't notice the weight, I only saw the size of the engine, and the power weight figures, and the fact it would be emissions compliant for the US.
If the figure is correct (does seem a tad large) that is almost as heave as a PSD...
