2000 explorer 4.0 code 1309
Old Sep 2, 2004 | 11:01 AM
mgast's Avatar
mgast
it says see service manual, does anyone know what it means.
later
matt
Old Sep 2, 2004 | 06:06 PM
mgast's Avatar
mgast
please help I can't figure it out
Old Sep 2, 2004 | 08:49 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Matt, P1309 refers to the camshaft position sensor (CMP). It's located either at the rear of the engine (ohv), or on the left valve cover (sohc). There's a testing procedure for it in the Haynes manual, involving checking for output voltage with a voltmeter. If you need the procedure, give us your engine type.
The code can be caused by a bad CMP, broken wiring connection, or the PCM itself. It's probably a bad CMP.
Welcome to the Ford Forum!
Don
Old Sep 3, 2004 | 11:51 AM
mgast's Avatar
mgast
thank you very much don for the reply, 2 weeks ago I pulled out the whole unit so I could clean it and lube it, now that it is back in it is throwing a code, the first thing that I will check is the wiring and that it is plugged in completley then if not is there any way to put it back in out of sync?
thanks
matt
Old Sep 3, 2004 | 02:45 PM
thelonerangerxlt
Matt, I assume you have the SOHC engine with the CMP on the valve cover? I don't think you can get it out of alignment unless the drive itself is removed. On the OHV engine, there's a special alignment tool that's used to reinstall the drive.
I believe the code refers to a loss of signal, so it's indeed possible that the plug isn't seated properly. Hope it's as simple as that. Let us know.
Don
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Feb 20, 2014 06:51 PM
