Bronco II Ford Bronco II
Looking for a new front end
Old Sep 2, 2004 | 10:25 AM
Mudder's Avatar
Mudder
hello,im finally starting to turn my B2 into the offroad truck i wanted. i just got done putting in a 4 inch rough counntry lift and 33 inch mickey thompson baja claws.Im looking to put a straight front end in it.ive heard that you can use the front end out of a jeep,im not 100% sure if this is true,any info would be great.thanks in advance
Old Sep 2, 2004 | 11:08 AM
Help I M Stuck's Avatar
Help I M Stuck
actually it's a front axle out of a 72-79 ford truck 4x4..you'll need the radius arms and buckets..the new radius arm buckets will get bolted to the frame just below the old ones..some drilling required. pretty simple..time consuming..i've done it.
