86 C6 questions
Old Sep 2, 2004 | 05:18 AM
Greg W's Avatar
Greg W
86 C6 questions
I have a C6 from an 86 F150 w/300 I6. It has some wires going into it. I want to put this in a 77. Will it work without the wires hooked up? If no, can this part that the wires go into be replaced with a part from an older C6 without the wires? I have 4 extra trannies for parts. Anything else need to be changed? How difficult is it to change these parts? I've never tore into an auto trans but I am mechanically inclined. Thanks for any help.
Greg W
Old Sep 2, 2004 | 08:33 PM
ecarter50's Avatar
ecarter50
That would be the neutral start/backup light switch. I think the switch is on the steering column in a 77. The shift linkage arm is different, you will have to remove the pan to replace it is fastened on the inside.
