wet stacking, what is it???????
Old Sep 1, 2004 | 08:45 PM
redbull660's Avatar
redbull660
Can someone explain to me what wet stacking is and how it effects a diesel engine. thanks
Old Sep 1, 2004 | 08:54 PM
johnsdiesel's Avatar
johnsdiesel
It's when diesel fuel makes its way into the oil from incomplete combustion. This is only a problem if you are idling the engine when it's not warm enough. This is the main reason not to idle your diesel for extended periods of time without an auxiliary idle controller. If it's warm outside don't worry about it, but in the winter idling a diesel to "warm up" is not a good idea unless you raise the RPM.
Old Sep 1, 2004 | 09:16 PM
gotdiesel's Avatar
gotdiesel
http://www.fordtrucks.com/forums/sho...d.php?t=276327
read this post it has some really good information for you. hope this helps. good luck
Old Sep 2, 2004 | 12:11 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Check out this link. The author has a different explanation of "wet stacking".
http://www.intellidog.com/dieselmann/b_smoke9.htm
Old Sep 2, 2004 | 07:10 AM
redbull660's Avatar
redbull660
thanks guys
90pioneer
Aug 23, 2014 07:53 PM
RRranch
25
Jan 7, 2010 10:42 PM
howardq99
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sep 20, 2006 08:12 PM
4x4turboterror
28
Dec 1, 2005 12:02 PM
TheSnowback
Jul 19, 2004 08:07 PM
