1978 - 1996 Big Bronco
Suggestions
Old Sep 1, 2004 | 05:34 PM
Himura77's Avatar
Himura77
Question Suggestions
I've a stock 88 Bronco 302/5.0L that I've been upgrading little by little...As the list goes, I've: Edelbrock Performer RPM intake manifold, power pulleys, 56mm B&M throttle body, throttle body spacer, K&N Air charcher, flexlite dual electric fan, oil/tranny cooler, short flowtech headers and dual exhaust. I'm in a budget so I'm looking to change the cam and pistons and probably up the throttle body to 61mm. Also, my Bronco is speed density, which I'm planning to change to mass air for X-tmas (gift from me to me).. So if anyone has any sugestions on some forged pistons and some cams, could you point me in right direction with part number and where to go. Any other suggestion would be appreciated..I just write this, cause even though I've seen some up in the power she's still not done, at least no on my book
Old Sep 2, 2004 | 02:58 AM
greystreak92's Avatar
greystreak92
Not sure about the cam and piston stuff but make sure you have the Edelbrock intake machined to match the 61mm throttlebody when you add it. That intake is port matched to the twin 56mm throttlebody and needs to be CNC matched for the 61mm.
Old Sep 2, 2004 | 03:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check with the 302 engine forum.
